So, I'm in a number of camping related groups on Facebook, regularly people ask for recommendations for a good cooler.
There are so many out there now, that's a tough question to answer, especially without knowing specifics. Area, type of use, frequency of use etc. Usually, I will answer by asking about the above mentioned variants.
Lately it's been a more generic answer. Today my response got a bit long winded. As I read back through it, I thought it would make a nice informative thread here and fit well in this section needing some more threads. So, hope it's okay and hope you find it helpful.
Most of the extreme coolers do well under normal camping conditions. I do think, in certain circumstances, there is a difference (IE: bear country, desert or extreme heat, commercial use such as a guide etc).
I have a Yeti, Gander Mountain roto molded, Coleman Extreme 6day and a regular Coleman. There is a significant difference between the regular Coleman and the rest. The others are pretty compareable under my camping use (which is very typical) weekend trips, a couple long weekends and a couple extended trips.
There are some things you can do to improve any cooler. A number of the roto molded coolers actually talk about this in their literature.
Pre chill your cooler. I put a couple frozen two liters in the night before a trip. Change the next morning before work, then again as I'm packing it to leave.
Fill with drinks etc that are already cold. Whatever meat I'm taking I take frozen, may leave one meal fresh so it's ready to go, the rest thaw as the trip goes.
Take two coolers. One for food, one for drinks. Constantly opening for drinks (especially if you have kids) will melt ice and lose cold fast. Food cooler only opened a couple times a day makes a huge difference.
A blanket or refectix can make a big difference. I don't use it, my Yeti (food) goes in a slide out tray in my campers galley so it's always in the shade. My drink cooler, I'll keep under the picnic table that's under my canopy.
I've talked with people in the past who were very unhappy with whatever extreme cooler they had. The majority of the time, those folks put hot drinks in a hot cooler but didn't understand why the ice was gone in less than a day. Coolers aren't designed to get things cold, they're designed to keep things cold. On extended trips, when I know I'll have to add more drinks, I take an extra cooler. When I get close to needing more drinks, I use it to get them cold so it doesn't kill the cold and ice in my main coolers.
A common misconception is leaving water in the cooler helps, that's not accurate. Water is warmer than ice, a bunch of water will melt the ice much quicker. I tend to drain water daily. I've done a ten day trip, in 90*+ temps, as described above with my Yeti 45 as the food cooler and only added one bag of ice one time.
One final thought (and sorry this got so long winded). If you have an extreme or roto molded cooler that has the rubber gasket and/or the rubber closures. Do not store it with the closures closed, leave them loose. Long term storage like that will compress the gasket and stretch the closures, greatly reducing the efficiency.
If you do decide to get one of the extreme/roto molded coolers, be sure you can get replacement parts, closures and gaskets especially. They do wear out over time and while they aren't cheap, they're certainly cheaper than a new cooler.
Happy camping!
B
Happy camping!
B
