This topic has been answered.
  • SteveC
    replied
ID:	20669 Click image for larger version
ID:	20670 Click image for larger version  Name:	IMG_0794.jpg Views:	0 Size:	449.2 KB ID:	20662 Click image for larger version  Name:	IMG_0795.jpg Views:	0 Size:	514.9 KB ID:	20663 Click image for larger version  Name:	IMG_0797[520].jpg Views:	0 Size:	329.6 KB ID:	20664 Click image for larger version  Name:	IMG_0798[521].jpg Views:	0 Size:	639.6 KB ID:	20665 Click image for larger version  Name:	IMG_0800[533].jpg Views:	0 Size:	513.2 KB ID:	20666 Click image for larger version  Name:	IMG_0802[525].jpg Views:	0 Size:	572.0 KB ID:	20667 Click image for larger version  Name:	IMG_0680.jpg Views:	0 Size:	897.3 KB ID:	20668
    Leave a comment:
  • SteveC
    replied
    Following photos show linear actuator to adjust the bed angle allowing comfortable reading or relaxing position.Control switches are up/down and center switch to turn on a reading light overhead.The control circuitry is tucked away under wheel well cover
    Leave a comment:
  • SteveC
    replied
    Originally posted by Zach View Post
    Nice plan! I've seen people in the Scotty groups handle it different ways. The fan with the relay is smart.
    Thanks.When AC is set on economy the AC blower turns off also and the current relay drops out the exhaust fan on shroud.No sense in it running continuous.
    Leave a comment:
  • SteveC
    replied
    Looking awesome! How are you dealing with the exhaust from the air conditioner?
    Got it installed and tested. Works great! Click image for larger version
ID:	20626 Click image for larger version
ID:	20627 Click image for larger version
ID:	20628 Click image for larger version
    Leave a comment:
  • Zach
    replied
    Leave a comment:
  • SteveC
    replied
ID:	20555 Click image for larger version
ID:	20556 Click image for larger version
ID:	20557 Click image for larger version
ID:	20558 Click image for larger version
ID:	20559 Pics of AC shroud
    Leave a comment:
  • SteveC
    replied
    current
    Thanks.Built a box (shroud) to fit around the rear of AC.Mounted an exhaust fan in shroud to turn on (using a current relay) when AC cycles on.Fan will blow hot air out through a vent in the floor using 6 inch flex duct
    from fan in the shroud.Will post assembled pictures when put it all together.Picture below.
    Leave a comment:
  • Zach
    replied
    Leave a comment:
  • SteveC
    replied
    Originally posted by MEBerberich View Post
    Steve, this is really nice! Shiplap looks great and the ceiling is amazing!!!!
    Thanks for the compliments.Hope to have it usable by the September gathering!
    Leave a comment:
  • MEBerberich
    replied
    Leave a comment:
  • SteveC
    replied
    Couple more Click image for larger version
ID:	20476 Click image for larger version
    Leave a comment:
  • SteveC
    replied
ID:	20474 Got some work done on the walls.Ripped some 5mm plywood into 7.25 inch wide strips to create a ship lap look.Got first coat of paint on. Click image for larger version
ID:	20471 Click image for larger version
ID:	20472 Click image for larger version
    Leave a comment:
  • SteveC
    replied
    Beds installed.Built these in sections a while back and just screwed together. Click image for larger version
ID:	19405 Click image for larger version
ID:	19406 Click image for larger version
ID:	19407 Click image for larger version
    Leave a comment:
  • SteveC
    replied
    Installed ac drip pan and drain Click image for larger version
ID:	19400 Click image for larger version
ID:	19401 Click image for larger version
ID:	19402 Click image for larger version
    Leave a comment:
  • Zach
    replied
    Looking great! I like the t&g interior! Good idea with the exhaust fan for the air conditioner. Should help its efficiency quite a bit.
    Leave a comment:
  • SteveC
    replied
    Built a circuit with current relay to turn an exhaust fan on when air conditioner cycles on.Explanation of above picture.
    Leave a comment:
  • SteveC
    replied
    Thr air conditioner will be mounted in the rear between the beds.
    Leave a comment:
  • SteveC
    replied
    Got some rough in wiring done.
    Leave a comment:
  • SteveC
    replied
ID:	18336 Click image for larger version
    Leave a comment:
  • SteveC
    replied
ID:	18328 Click image for larger version
ID:	18329 Click image for larger version
ID:	18330 Click image for larger version
ID:	18331 Finally got the ceiling installed.Used 1/4 inch pine tongue and groove.Finished the boards before installing,It was time consuming and a chore but hopefully when I look up at the ceiling at night it will be worth it.
    Leave a comment:
  • SteveC
    replied
    Removed both disentegrated roof vents.Did away with the one on outer edge and covered with aluminum sheet.
    Since I was replacing center vent I added a nice 3 speed fan.
    Now that the roof holes are plugged I can start hanging the inside ceiling.
    Leave a comment:
  • SteveC
    replied
    Finally got a little done on the project. Click image for larger version  Name:	IMG_0506[133].JPG Views:	0 Size:	101.3 KB ID:	14377 Click image for larger version  Name:	IMG_0507[135].JPG Views:	0 Size:	85.0 KB ID:	14378f Click image for larger version  Name:	IMG_0508[136].JPG Views:	0 Size:	95.0 KB ID:	14379 Click image for larger version  Name:	IMG_0509[137].JPG Views:	0 Size:	89.5 KB ID:	14380
    Leave a comment:
  • Zach
    replied
    Making some good progress!
    Leave a comment:
  • SteveC
    replied
    Beds on each side will face to the rear . The cutout in rear is for the AC.
    Leave a comment:
  • SteveC
    replied
    Originally posted by Nick T View Post
    Steve, in addition to your photo posts being interesting & informative, you may have also saved me the trouble of starting a new thread & posting my "problem photo" showing the original tongue & jack on my '66 Shasta. The jack no longer works because sometime in its prior life it got bent/banged up, and no longer cranks. It's basically stuck in a fairly low position (about like where yours is, in your photo above, if you include the length of the removable "foot" shown in your photo). I've been wondering what to do about that, which sections were replaceable, which replacement parts were readily available, whether I'd have to cut it out with a torch vs be able to unbolt it, etc). It looks (operative word) like I should (hmmm) be able to unbolt "just the jack" exactly the way yours is unbolted and replaced, above. Did you have any trouble getting your ancient bolts to come out? The very few times I used my Shasta, years ago, I had a picThe kup that was "lifted" so a low, non-functional jack wasn't a significant problem (there was no risk of it dragging or snagging, hitched to a tall bumper). Now I have a stock height small pickup, and the frozen-in-place jack would probably drag. Where did you get your jack?
    Original jack was already gone when I bought it but he gave me new one he hadn't installed.The hole in the A coupler had to be enlarged a little (used a grinder) for the new jack to fit.The bolt holes lined up perfect
    and just bolted right in.
    E Trailer has several model jacks and of course Amazon has everything.
    Leave a comment:
