Good day to all of you!
I wanted to share my build with you all from start to finish. I started my build in April 2020 during the Covid shut downs in my home state of KY. Before the shut downs, I had already hired a friend of mine to build the trailer frame and had ordered some parts. When we were all forced to stay at home to "flatten the curve" I started building my camper. I originally wanted to build something similar to the Oregon Trailer Do Drop Alpha, but decided on a smaller version of a build I saw online called the Saw Tooth.
The Trailer:
I started with a home made frame built out of 2x2 square tubing that had 1/8 inch wall thickness. For axles I used the Timbren axle less suspension coupled with idler hubs with the same bolt pattern as my Tacoma pickup truck. I used a 2 inch female receiver hitch for the tongue for using a lock n roll style hitch. I added scissor type leveling jacks on the rear of the trailer and a swiveling tongue jack with a dual wheel at the front of the trailer. I used the same wheels as my truck with the same size tire. I bought a complete set of wheels and tires used from a friend. While the tire tread is different than what is on my truck, the tire size is the same so I only have to have one spare between the truck and trailer.
The Trailer:
