Hoping someone can help with an electrical question.
My whole system at this time is 12v.
I currently have a battery monitor hooked up with my 200ah lithium battery. The specs on this are as follows.
Working voltage: 8.0-80.0 V
Current range: -100~+100 amps
Capacity range: 0-999 ampere-hour
I am getting ready to wire a 1500w inverter, and I would like to run it through my battery monitor so I can see how much battery it uses.
I don't need to monitor the output of the inverter, just the output of the battery.
I will only be using the inverter when we aren't at an electrical site, and only to boil water with a 1000w water kettle.
The question I have is, do I need to upgrade the battery monitor to run this inverter?
It seems that there will still only be 12v running from the battery, through the monitor to the inverter, where it will be converted to 120v.
Or do I have that totally wrong??
Will there be 120v running through the wire from the battery to the inverter when I have the inverter going, which is outside the max 80v that the monitor can handle?
I don't want to blow anything, so do I need to get rid of this 100A and go to the 350A, or will this one be just fine?
Thank you!
