Mine is only 75 amp hours. So at 50% which is the rule for Led batteries I only have about 35 amp hours. Only had my teardrop a week but have used it many times. My fan on each of the four speeds draws 1 amp or 2 amps or 3 amps or 4 amps. Lights are probably less than an amp. I should be able to run the fan on medium for 17 hours which is 2 nights. On my YouTube travels I see people with hundred amp hour batteries and they are agm. I'm going to see how my works out for now but it is just a cheap Marine deep cycle battery that came with it. I'm already doing other upgrades and the battery is probably last if it becomes an issue.
